JTV-89-US
Expertly crafted in the United States, JTV-89-US is an electric guitar of the highest caliber. This hard-rocking powerhouse marries incredible Variax® technology with a sculpted mahogany body and a quarter-sawn, three-piece maple neck with 24-fret rosewood fingerboard.
A pair of custom, high-output, alnico humbucking pickups—wound to James Tyler's specs—translate this powerful instrument to the amp of your choice. The unique Tyler-designed, fully adjustable wraparound bridge redefines resonant coupling between strings and body (in black nickel, naturally). The reversed 6-in-line headstock and choice of six hand-sprayed finishes complete the package.
Head-turning Looks
The Extra Mile
